Urgent Exam Preps -CAD
DwarkamaiH
Giga Contributor
Which one of the following is NOT a GlideUser API (g_user) method ?
getFullName(),
hasRoleExactly(),
hasRole(),
UserName(),
HasMultipleRoles
what will be the answer if select only 1 or select 2
Tanushree Maiti
Tera Sage
  • If you must select ONLY 1:
    • HasMultipleRoles
  • If you must select 2:
    • UserName()
    • HasMultipleRoles
Please mark this response as Helpful & Accept it as solution if it assisted you with your question.
Tanushree Maiti
Linkedin:
SP22
Hello @DwarkamaiH,
  • g_user.UserName()  Not valid. The correct property is g_user.userName (lowercase “u” and not a method).
  • g_user.HasMultipleRoles  Not valid. There is no such method or property in the GlideUser API.
    SP
Tanushree Maiti
Tera Sage
    • HasMultipleRoles
    • UserName()
    • HasMultipleRoles
Tanushree Maiti
Linkedin:
Tamizhv
UserName() -  Wrong Method
HasMultipleRoles - Not a GlideUser method at all.
Please select both the option 2
GlideFather
Hi @DwarkamaiH,
the best way to learn is to search by yourself rather than to ask strangers online and memorise what they say... trust in yourself more than in others!
To see the correct answer, refer to this GlideUser - Client
_____
100 % GlideFather experience and 0 % generative AI
