‎11-04-2025 06:29 AM - edited ‎11-04-2025 07:03 AM
Good Morning all--thanks in advance for your help!
Have a request to validate data on Demand record/form for a specific field.
There are existing values in field and we are not cleaning those up..
Sorry fairly new to scripting so be patient..
1. I would change the character limit from 100 to 4 on that field (however I cant because there are 1,000 records with garbage data in that field and we are leaving for now.. (not my call)
2. Required field format is a combo of letters & #'s (alphanumeric & always 4, example Z123)
this is my script however Im able to put any value in and save the record (see attached screenshot also)
or is there a better way to accomplish this? (this is the "on submit" client script, I would have to create an "on change script also)
}/function onSubmit() {
var fieldName = 'u_car_numbr'; //
var fieldValue = g_form.getValue(fieldName);
var regex = /^[a-zA-Z0-9]*$/;
if (!regex.test(fieldValue)) {
g_form.showFieldMsg(u_car_numbr, 'Only alphanumeric characters are allowed in this field.', 'error');
return false; // Prevents form submission
return true; // Allows form submission
Demand Management
‎11-04-2025 07:59 AM
Hi @Community Alums ,
I tried your problem in my PDI and it is working fine, Please check below onSubmit Client Script
var fieldName = 'short_description'; // Replace with your actual field name I gave short_description to test
var regex = /^[A-Za-z0-9]{4}$/;
g_form.showFieldMsg(fieldName, 'Value must be 4 alphanumeric characters (e.g., Z123).', 'error');
return false;
return true;
Result:
Please mark my answer correct and helpful if this works for you
Thanks and Regards,
Sarthak
‎11-04-2025 07:09 AM
Hi mborkowski,
Please test the following scripts - they should work. I see that also the name convention is not the best (like errors in u_car_numbr), but I left it as it is, so the scripts should work,
Client script (onChange):
if (isLoading) return;
var field = 'u_car_numbr';
var value = (newValue || '').toString().toUpperCase();
if (value !== newValue) g_form.setValue(field, value);
var pattern = /^[A-Z][0-9]{3}$/;
g_form.hideFieldMsg(field, true);
if (value && !pattern.test(value)) {
g_form.showFieldMsg(field, 'Format is wrong: letter (A–Z) + 3 digits, for example Z123', 'error');
Client Script (OnSubmit):
var value = (g_form.getValue(field) || '').toString().toUpperCase();
if (!value) return true; // Allow empty value if the field is not mandatory
if (!pattern.test(value)) {
return false;
return true;
You should consider writing a Business Rule in the future as well, to prevent clients from bypassing the check via import/integration. But this is another story, haha. These client scripts also don't block updates to records with "old" garbage values ​​if the field hasn't been changed.
If it was helpful to you, please mark it with a thumb up. Thank you!
Best regards,
Renat Akhmedov
‎11-04-2025 07:18 AM
g_form.showFieldMsg(fieldName, 'Only alphanumeric characters are allowed in this field.', 'error');
replace your script with above and try
Please mark my answer as helpful/correct if it resolves your query.
Chaitanya
‎11-04-2025 07:44 AM
Hi @Community Alums
Your current regex allows any alphanumeric string of any length. To enforce exactly 4 characters and start with a letter, update the regex like this:
var regex = /^[A-Za-z][A-Za-z0-9]{3}$/; // Starts with letter, followed by 3 alphanumeric chars
g_form.showFieldMsg(fieldName, 'Value must be 4 characters: start with a letter, followed by 3 alphanumeric characters (e.g., Z123).', 'error');
return false;
return true;
you can use similar on onchange as well.
return false;
return true;
Result:
Thanks and Regards,
Sarthak
