Remove Project Task Dependency through fix script
07-23-2023 07:14 PM
i am having a difficulty in removing project task dependencies in bulk via fix script. I was able to remove the task relationship through this fix script, but the dependencies still showing in list view. Even .deleteRecord(); produces same results.
Note: Tried to delete values from dependency field as well, but list view values are still visible.
May i know what is the best way to remove project task dependencies in bulk?
Thanks in advance!
06-11-2024 01:45 PM
Hi Rahul,
I have the same kind of request.
I want to remove the current value in the "Parent" and "Top Project" fields on the Project task table( pm_project_task)
Could you please provide the script?
Thank you
Prabhu Mendu
07-23-2023 11:36 PM
@Ahyel Libunao1 ,
Can you open a record and see the field name and type for dependency, Post a SS for same
07-24-2023 12:14 AM
