Approval in Flow Designer
Merza Lyn
Giga Guru
I created a catalog item with 2 approvals.
1st approval is the user manager
2nd approval is based on the category.
If user manager approved the request, it will move to the 2nd approval.
If user manager rejected the request, it will end the flow (Cancelled).
Then if the 2nd approval, approved the request, it will end to flow (Completed).
If rejected by the 2nd approval, it will end the flow as well (Cancelled)
In my flow, where can I add the decision for Category?
@Merza Lyn
Hope you are doing good.
