05-13-2025 05:43 PM
Did you add and post a comment?
Task Instructions:
Assume that Adela Cervantsz reached out via a phone call describing intermittent email access for her group.
Create and submit a new incident to assign this trouble ticket to the Software group. Then post a Customer visible comment to the incident.
Incident details:
- Subcategory: Email
- Impact: 2 – Medium
- Urgency: 2 – Medium
- Assignment group: Software
- Short description: Intermittent email access
- Description: The department is experiencing intermittent email access. Please help!
- Post a comment to the incident: The software group is investigating similar incidents and will respond when they have a resolution.
05-14-2025 08:17 AM
Hi @PBreezer1
The issue might be because you didn’t impersonate the correct user, which is causing the issue. Also, make sure you're entering comments in the 'customer visible' section only. Sometimes, it could be a data issue, so don’t spend too much time on it. Try the next task and come back to this again later or tomorrow.
06-25-2025 06:13 AM
sir i am completed but not validate task submitted
09-14-2026 03:21 AM
hi could you please help me about this task I have the same issues.
07-13-2025 04:25 AM
how to create command
02-14-2026 06:23 AM
yes
08-28-2026 02:40 AM
I am having same issue since last week
