Flow Designer - can't find Set Flow Variable?
ChinchillaMoMo
Mega Guru
Hi guys,
I was trying to build a flow with flow designer, then I created a decimal type variable, but then I can't find the Set Flow Variables action in my developer instance, anyone knows what is missing?
Besides, it is possible to do some formula / calculations within flow designer? I actually wants to sum up a currency field from previous lookup records and then assign this sum to another field.
Excuse me if it is a silly question as I'm new to ServiceNow.
Thanks so much!
Best,
Sam
Oh, I found out why, it is under flow logic, not action....thanks @Ankur Bawiskar
11 REPLIES 11
Hi @Ankur Bawiskar , they are set like these, are they wrong? Thanks so much!
@ChinchillaMoMo
try clearing instance cache using cache.do
Also try creating fresh flow
You just ended 4 days of researching.
Thank you!
L_Pear
The option is located at the bottom of Flow Logic
