Help in PA indicators and PA Widget setup
Suz Roque
Hi, i have very little experience in  Performance Analytics.
We have a requirement to create a 1 PA widget in Dashboard containing KPI in  Idea table checking whether customers A, B, C (Customer is a reference field in Idea table that is populated by user) are creating 4  idea records per month and need to display this in like percent of what is achieved as of the current date
Example. If Customer A created  2 idea records, it should show 50% for customer A, in that same widget, if Customer B created 4 idea records, it should show 100%.  It should display the percentage for customer A, B, and C (bar chart) and when clicked per bar, it should display the daily history like when the ticket is created etc.
Please help me in setting this up.
Bert_c1
1. Create an Indicator source for the Idea table:
https://docs.servicenow.com/bundle/utah-now-intelligence/page/use/performance-analytics/concept/c_In...
Set "Facts table" to 'idea', "Valid for frequency" to "Monthly", and one Condition 'Created', 'on', 'This month'
2. Create a Data Collection job:
https://docs.servicenow.com/bundle/utah-now-intelligence/page/use/performance-analytics/concept/data...
(I haven't found documentation of how to fill out the form, but there are videos available.)
See attached screen shot
Set the timezone and time as desired.
3. create an Indicator:
https://docs.servicenow.com/bundle/utah-now-intelligence/page/use/performance-analytics/concept/auto...
"Unit" can be '%' (On General page), set "Indicator source" to the indicator source created in Step1. Fill out the remaining fields similar to the following screenshot
Once that is working the way your want. You can refer to:
https://docs.servicenow.com/bundle/utah-now-intelligence/page/use/performance-analytics/concept/c_Wi...
I hope the above helps. Please see:
https://www.youtube.com/results?search_query=servicenow+performance+analytics
for more assistance.
Bert_c1
Let me know if you want the update set, it is a start. The included widget needs to be added to a PA Dashboard. The Data collection job may need adjusting for your requirements. I have tested it in a San Diego and Rome instance. it was developed on Utah.
Yes please! Kindly send me the attachments. thank you!
Bert_c1
Here it is, it does not change anything existing. and can be backed out cleanly if desired. the widget is a PA Breakdown widget, easy to add to a PA Dashboard.  Tweak what is present as needed.
