How to copy variables field values from RITM and insert that it to new record target table?
Michael Galang
I'm working on a catalog item that should automates the Newsletter Subscription.
Every new subscription request after it approves by the user's manager should automatically run a script in the workflow that will copy the highlighted field values as shown in RITM reference(Picture 1) and insert all of these to a new record in the target table(u_newsletter_subscription) form(Picture 2),  then automatically submit the new record. The new record should be reflected in the Table list(Picture 3). Please see below  script code that I put in the Run Script in the Workflow and it seems there are missing in my below script codes that it not working based on the expectation.
I would appreciate for any help. Thanks in advance.
//GlideRecord Query
var getTicket = new GlideRecord('sc_req_item');
getTicket.addQuery('number', variables.current.number);
getTicket.addQuery('requested_for', variables.current.requested_for);
getTicket.addQuery('requested_by', variables.current.requested_by);
getTicket.addQuery('end_date', variables.current.end_date);
getTicket.query();
if(getTicket.next())
var recinsert = new GlideRecord('u_newsletter_subscription');
recinsert.initialize();
recinsert.setValue('number', number);
recinsert.setValue('u_requested_for', getTicket.variables.requested_for);
recinsert.setValue('u_requested_by', getTicket.variables.requested_by);
recinsert.setValue('u_end_of_subscription', getTicket.variables.end_date);
recinsert.insert();
var createSub = new GlideRecord('u_newsletter_subscription');
createSub.initialize();
//fill out fields
createSub.u_requested_for = getTicket.current.variables.requested_for;
createSub.u_requested_by = getTicket.current.variables.requested_by;
createSub.u_end_ofsubscription = getTicket.current.variables.end_date;
createSub.insert();
I found some errors errors in your script:
You are glide query RITM table, if you are using run script in workflow no need to glide query ritm, you can use current method to get variables like current.variables.requested_for.
Even in the addQuery method, you are adding parameter as
getTicket.addQuery('number', variables.current.number); its wrong it should be
getTicket.addQuery('number',current.variables.number); thats the reason you are not getting value while insert
Write a workflow run script like below to insert record in newsletter subscription table and it should work:
//fill out fields
createSub.u_requested_for =current.variables.requested_for;
createSub.u_requested_by =current.variables.requested_by;
createSub.u_end_ofsubscription = current.variables.end_date;
createSub.insert();
Please try and let me know.
Faizeal.
Michael Galang
Hi Mohamed,
It works now! Thanks a lot. I appreciate your help.
