Requested Item in flow
Everson Alves
Is there any way to call the sc_req_item table directly from the flow?
Ankur Bawiskar
@Everson Alves
Platform limitation won't allow you to select the trigger flow on sc_req_item table.
You can configure flow on the catalog item with trigger as "Service Catalog" and then have your logic inside it.
[sc_req_item] Table not available on Trigger of Process Automation Designer
