Flow Designer: Create a Flow Course
DiannaS
Kilo Expert
Hello Everyone,
I am hoping someone can provide answers here. I am going through the "Flow Designer: Create a Flow" class and am getting stuck where I am supposed to "End" my Flow Logic
  • Select Done.
    Add an End Flow Logic option below the Update Monitor Record action. This will stop the execution of the flow. Remember that End Flow is found under Flow Logic.
I actually can do this, can find it, can see it, however, the option is grayed out and won't actually allow me to select it. I have gone through the lesson twice and it lets me the first time, but not the second, so I am stumped.
Has anyone else experienced this, or am I missing some steps the second time around?
Thanks for any input. I would love to complete this class.
Dianna
2 ACCEPTED SOLUTIONS
Kieran Anson
Hey Dianna,
I've done this course but as an FYI you can't add an 'end' flow logic step unless you're in a branch.
Below, I'm on the main path of the flow, so can't end it as it's implicit
Below I'm in a branch, so can end the flow
(p.s screenshots are a big help on the community, if the above doesn't help. Post some screenshots of your steps and someone will be able to help)
Hi Kieran,
This is very helpful! I am going back to see where I missed it and give it a try. If I can't figure it out, then I will take screenshots and repost. Thank you so much for the quick reply and super awesome screenshots!
Dianna
Kieran Anson
Hey Dianna,
Hi Kieran,
Dianna
Hi Kieran,
This worked! Thank you!
Dianna 😊
Glad that worked, if you could mark my answer as the solution I'd be greatful
