how we will get variables of catalog item in flow designer?
rani3
which action we have to for scheduled jobs in flow designer?
Hi
yes, in case you mean how configure scheduled execution of a Flow you can use the respective triggers
Maik
Hi
Maik
MrMuhammad
Can you explain the use case for scheduled job action in flow designer? what exactly you want to achieve with that may be there is action with some other name that can be of help.
In case if you want to create scheduled job via flow designer then no action is available OOTB but you can create a Custom Action.
Hope that helps!
Muhammad
Muhammad
rani3
thank u for clarification
Rani - Is your query is resolved? Please close the thread by marking the response as correct. It will benefit future users with the same question.
- Muhammad
Muhammad
