Fetch subflow input and flow variable in script
FarukhKhan1
I am trying to write a logic with the Subflow input and flow variables. But dont know the object name and the syntax to fetch it in the script.
In flow designer, we use fd_data, I am looking for the same kind of object for subflow which I can use for fetching the value of IP and Adbor_Id.
Farukh
chaithu1489
custom script is a custom action that you created?
Yes, but this question is generic one. If we need to add an inline script for any activity under a subflow, how to do that?
in below scenario, I am trying to add an inline script for adding logic to set the adbor_id based on input and other flow variable. Please help me out with the syntax that can do this.
This is my sub flow and it is working fine
