How many days in advance should I schedule instance cloning?
ayano
Giga Guru
When I set up cloning in a production environment, how many days in advance do I need to submit it?
@ayano In ServiceNow, the ability to set a clone schedule depends on the lead time required by the system. Typically, you cannot schedule a clone less than 24 hours in advance due to the time needed for planning and resource allocation. However, this timeframe might vary depending on instance size, ServiceNow version etc.
ayano
Giga Guru
Hi @Dr Atul - LNG ,
Thank you for your comment.
In my experience, I have been unable to set a schedule for cloning if it is too close to the schedule.
Do you know how many days in advance you can't set a schedule?
Hi @ayano
I think, if you login to Support portal, you can see , as per my experience it can be 1 day advance as well, but to sure check in Support portal.
