Instance management - best practise
Guled Yusuf
Hi, the team and I discussed general best practices today but did not agree on a specific topic.
What is the right way to handle emergency updates on production instances?
Example - The update set is moved to production and for some reason, the change applied needs to be turned off until a complete fix is ready in the next update set.
1 - Is it right to just deactivate the introduced component in production? Like an ACL rule that was introduced.
2 - Or should you not deactivate it manually and just push a new update set where this ACL is deactivated?
Will there be any downsides if we manually deactivate the introduced component directly in production? Example Business rule, new ACL, etc. This would be the fastest way, but we need to understand if it goes against best practices and why.
Thanks!
3 ACCEPTED SOLUTIONS
Allen Andreas
Some would say that you would backout the update set, but I don't necessarily agree with that unless the update set in question only contains that one piece. I actually created a video on my YouTube channel about the hidden risks of backing out the set.
Anyways, you can easily just deactivate the record for now, if it's sincerely causing problems, then have the team work on it properly and promote the record back up. When you go to commit it again in Prod, you'll most likely see a preview warning telling you that the record in Prod has been adjusted and so you'll just want to accept remote update anyway and it'll bring up your change successfully.
@Guled Yusuf
To follow-on to the guidance shared above, by me, and below, by Mark...you'd want to revisit this issue with your teams to find out why it may have happened in the first place.
  • Was proper development not done previously?
  • Was it not tested?
  • Were the lower environments not in sync with Prod so there was a difference in behavior?
  • Something else?
You'd still want to revisit the process cause of the issue and try and correct that as the most important and long term outcome here.
As I mentioned above, if an issue is causing a critical issue that's impacting your business, then all kidding aside...you need to deactivate the issue. Period. If it's not that urgent and can wait until later in non-peak hours, then consider having your team work on a "hotfix" to quickly address it...even if it's passing up an update set that contains the deactivation of that record (business rule, client script, etc.). Then, later, they can resume working on it in Dev and again bring it up properly.
I think you get the idea with deciding to make that decision in Prod or not based on the urgency/criticality.
Thank you for the great answer, Allen. This is exactly what we discussed. We fixed it by deactivating it and then pushing an update set that fixes the issue, deactivation was done since it was critical at the time.
Our disagreement was more about why we should not deactivate components in production. Some people are of the nature that nothing should be changed in production, while I do not see this as an issue since the deactivation is on an isolated and newly introduced component and it will close out the critical issue right there so we get time to push a long-term fix. That is why we were interested in hearing about the pros and cons.
I agree with the mindset of changes in production = possible development. But would you say deactivating the introduced components is on the scale of actual development? We are trying to understand where the line goes (by best practice), and what is an acceptable fix before we say "No go push the fix through the typical development process like dev-test-prod". This is why we need to understand the upsides/downsides of this situation.
In ServiceNow terms, yes its development. We cannot argue on that 😀. Maybe not in your company terms, though in ServiceNow terms, yes its development.
Its just what mentioned before. Ofcourse do have to look at it from a practical point of view ofcourse. If it's a P1, whole organisation can't work etc.... you have to be a bit more flexible a break the "rules" perhaps. Though else, avoid doing so as much as possible. I see this over and over at customers, and eventually it becomes the norm and it's very normal to do a quick manual change in production. And yes, ofcourse at some point that does go wrong 😁.
Or for some type of companies such development is not allowed from a regulations point of view, how to explain than that such was done on purpose? While for other type of companies this is no issue it all.
