Sentiment analysis fields not showing
08-26-2025
03:09 AM
- last edited on
09-15-2025
07:59 AM
by
LisaLatour
Hello Community,
I am in a paid instance where I have set up an LLM model to analyze the ticket sentiment following this guide
Everything is working as expected but the Sentiment analysis fields. Following the guide I should see: Current sentiment and Sentiment over time fields. However on the Layout I can only see "Sentiment". After that I have followed this other guide. But this did not solve my issue. Let me show you how I am seeing it:
As you can see I am seeing the RAW record instead of the UI elements. Anyone Knows what might be happening?
Thank you,
Kind Regards.
08-28-2025 12:44 AM
Thank you for your reply,
Before continue, I would like to ask you if this LLM sentiment analysis model can be used for the ITSM module (requests, incident). Because all the documentation I find is about the CM module (Cases - CS)
Thank you,
Kind Regards.
07-01-2026 07:56 AM
We had this issue, it had to do with the display values on the sentiment tables.
