demos for flow designer vs. workflow editor
nechma
Tejas Adhalrao
Hi @nechma  ,
Workflow in ServiceNow
Traditional graphical tool, great for legacy processes. It uses activities like approvals, conditions, timers, and scripting to define process flows. Ideal for complex logic and heavy scripting needs.
Flow Designer
A low-code, modern alternative introduced to simplify automation. With a more intuitive interface, it allows building flows using triggers and actions—perfect for citizen developers and quick process builds.
📍Key Differences:
🌳Interface: Workflow is form-based; Flow Designer is more visual and interactive.
🌲Ease of Use: Flow Designer is low-code; Workflow often needs scripting.
🌴Future-Focused: Flow Designer is the way forward with more ServiceNow updates emphasizing it.
refer this article by servicenow :- https://support.servicenow.com/kb?id=kb_article_view&sysparm_article=KB0789014
https://www.youtube.com/watch?v=uwWLlOqum9c
 If you found my solution helpful, please mark it as Helpful or Accepted Solution...!
thanks,
tejas
Email: adhalraotejas1018@gmail.com
LinkedIn: https://www.linkedin.com/in/tejas1018
thanks Tejas Adhalrao for your detailed response
Tanushree Maiti
ServiceNow Flow Designer is the modern, low-code, and recommended tool for building automated processes, offering a natural language interface, extensive integration via Spokes, and improved reusability compared to the legacy, scripting-heavy Workflow Editor.
Flow Designer is ideal for new developments, while Workflow remains functional for complex, heavily scripted legacy processes
Key Differences between ServiceNow Flow Designer
Future Development: ServiceNow directs new development toward Flow Designer.
Skill Set: Non-technical users can use Flow Designer, whereas Workflow often requires developers.
Flow Execution: Flows run as efficiently as business rules, avoiding performance slowdowns.
Complexity: Flow Designer is better for linear, simple processes, while Workflow handles complex, non-linear logic better.
ServiceNow Flow Designer (Modern)
Interface: Web-based, intuitive, uses natural language.
Approach: Low-code/no-code; utilizes "Actions" and "Data Pills".
Reusability: Highly reusable via subflows and custom actions.
Integrations: Excellent; built-in Integration Hub spokes.
Performance: Lightweight, designed for better performance.
Best for: New automations, simple to moderate logic, API integrations.
ServiceNow Workflow Editor (Legacy)
Interface: Flash-based canvas, drag-and-drop.
Approach: High-code; requires scripting for complex logic.
Reusability: Limited, often tied to specific tables.
Integrations: Limited compared to Flow Designer.
Maintenance: Generally harder to maintain.
Best for: Legacy processes, complex branching, scenarios requiring advanced timers/SLA.
Aditya_hublikar
Hello @nechma ,
Workflow is a legacy automation engine using Workflow Editor, while Flow Designer is a modern low-code automation tool recommended by ServiceNow for building integrations and process automation.
 more plus point of flow designer is :
custom action : we can create our own custom action which we can't create in workflow
integration hub : It provide prebuilt connectors(spoke) and template to simplify connections(integration connection)
flow designer has better ui and other functionality as compared to workflow(drag and drop functionality, data pills,flow variable ,decision table , subflows , playbooks)
You can refer this :
https://www.servicenow.com/community/servicenow-ai-platform-forum/when-to-use-flow-designer-vs-workf...
https://www.servicenow.com/community/servicenow-ai-platform-forum/what-is-the-difference-between-flo...
https://www.servicenow.com/community/developer-advocate-blog/workflow-studio-amp-flow-designer-in-wa...
https://youtu.be/W-DqvcvRLws
If this helps you then mark it as helpful and accept as solution.
Aditya
Hello @nechma ,
I hope you are doing well. Does my response helps you ?
If my response helps you then mark it as helpful and accept as solution.
Aditya
