How to split string in flow designer?
nayanmule
I want to get values from one field in change request & populate it in another field on a change task form.
for eg. if I have a Change Plan field which has following values -
newservername = testt123
oldservername = test256
cutoverdate = 03/23/2025
plantname = US
plantid = 1356.
I want to populate these values in change task description .
for eg. Change task - Update the 'newservername' to 'oldservername'.
I have multiple change tasks created through flow designer. I would like to know how can I split the string and use the values in change tasks or anywhere I need in flow designer.
Thankyou!
nayanmule
Thankyou everyone for your responses.
I have achieved it by creating an action. Within an action, I have added a script using inputs and outputs.
// ... code ...
var data = inputs.inputString;
var lines = data.split('\n');   // this will split the string based on lines
var values = [];
for(var i=0;i<lines.length;i++){
    var parts = lines[i].split('=');    //this will split the string one more time using =
    if(parts.length  === 2){
        values.push(parts[1].trim());   //trim the second value string to remove unwanted spaces.
outputs.newservername = values[0];
outputs.oldservername = values[1];
outputs.cutoverdate = values[2];
nayanmule
// ... code ...
var values = [];
Great that this works, but do realize that the Change Plan field is a string field and can contain lots of things. If any one, at any points switches lines, or adds lines to it, your order isn't correct anymore.
Mark
