I need to send notification on employee work anniversary.
niveditakumari
To achieve that I have created :
1. Event
2. Schedule Job
gr.addQuery('active=true^u_hr_hire_dateISNOTEMPTY^nameLIKEnivedita');
while(gr.next()) {
    var hireDate = gr.u_hr_hire_date; //this field is date of joining
    var hireMonth = hireDate.substring(5,7); //getting month from date of joining
    var hireDay = hireDate.substring(8,10); //getting day from date of joining
   var todayDate = new GlideDateTime();  //getting today date
    var todayMonth = todayDate.getMonth(); // getting today month
    var dayOfMonth = todayDate.getDayOfMonthLocalTime(); // getting today day
    gs.log('hire date is' + hireDate);
    gs.log('hire month is' + hireMonth);
    gs.log('hire day is' + hireDay);
    gs.log('today date is' + todayDate);
    gs.log('today month is' + todayMonth);
    gs.log('today day is' + dayOfMonth);
    if(hireMonth == todayMonth && hireDay == dayOfMonth) {
        c++;
        gs.eventQueue('sn_hr_core.work.anniversary.notification', gr, '', gr.name);
        gs.log('notification sent');
    gs.log('count is' + c);
When I'm writing code for nivedita for particular user then it is checking if condition and it is executing code that is written after if condition but when I'm writing code for all user it is not checking if condition.
var c= 0;
gr.addQuery('active=true^u_hr_hire_dateISNOTEMPTY'); /////////////////////////////////////////////
while(gr.next()) {
    gs.print('hire date is' + hireDate);
    gs.print('hire month is' + hireMonth);
    gs.print('hire day is' + hireDay);
    gs.print('today date is' + todayDate);
    gs.print('today month is' + todayMonth);
    gs.print('today day is' + dayOfMonth);
        c++;
        gs.print('notification sent');
    gs.print('count is' + c);
Can you please help me to correct that code.
Nivedita
Hi @niveditakumari ,
Adjusted the code to below as I wasn't aware that your "Date Of Joining" field was not a date field.
var gr = new GlideRecord("sys_user");
gr.addQuery("active=true^u_date_of_joiningISNOTEMPTY"); // Query for active users with a joining date
while (gr.next()) {
    var jdate = new GlideDateTime(gr.u_date_of_joining); // Parse u_date_of_joining
    var to_date = new GlideDateTime(); // Current date
	gs.print(jdate.getDayOfMonth());
    // Compare day and month
    if (to_date.getMonthUTC() == jdate.getMonthUTC() && to_date.getDayOfMonth() == jdate.getDayOfMonth()) {
        gs.print("Hi, it's the user's joining date anniversary!");
        gs.eventQueue("joining.notification", gr, gr.name.toString(), gr.email.toString());
Please try using this script and let me know if there are any further issues.
Please mark this solution as "Helpful" and "Accepted Solution" if this solution helped you in any way.
Thanks and Regards,
K. Sai Charan
Sr. ServiceNow Developer
Deloitte India
32 REPLIES 32
Hi @Ankur Bawiskar,
Can you please help to correct code.
Nivedita
@niveditakumari
seems the field is empty for the user record
are you sure the field name is correct?
You can use a schedule job to achieve your requirement.
To test click on "Execute Now" button and verify whether emails are triggered.
Ensure your notification is triggered when event is fired.
Hi @shivatmika_19,
Can you please confirm how you have calculated years like in preview email it is showing Congratulations on Amazing 2 years, Abel Tutor.
Nivedita
I used an email script for that.
Use ${mail_script: email script name} where ever you require in the notification body
