Move users from Group A to Group B using background script.
nebiata
I have 100 users who need to be moved to Group A from Group B. They also need to be removed from Group A using a background script.
Thank you
12 REPLIES 12
I did see that script and did not work for me. I am deleting any role. Just want to move 125 out of 700 users from Group A to Group B.
thank you
Danish Bhairag2
Tera Sage
Hi @nebiata ,
  • Open sys_user_grmember table
  • Bring all 125 records by applying the filter .
  • Right click on any of the column from the table
  • Select Data Management u will see 2 options Delete data & update data
  • Select update data with preview.
  • It will open up one window with ur filter applied.
  • Under values add group is group b save the record don't press update, save it & press execute now from related link.
  • All 125 records will be updated to Group B
Danish
Closer and closer 🙂 However, I don't see "group" unde
r field and value
Hi @nebiata ,
Let me check this. Never tried on group member table.
Danish
Hi @nebiata ,
It is coming for me .I have taken a snip from my mobile. Kindly adjust
Danish
