powershell script is not working in flow designer
Hi Team,
This script is not working in the custom application:
We are giving the user name.
Import-Module ActiveDirectory -WarningAction SilentlyContinue
# Try to get the username from the environment variable
if (Test-Path env:\SNC_userName) {
$username = $env:SNC_userName
Write-Host "Environment variable 'SNC_userName' not found. Please provide a username."
exit
# Clean up the username if needed
$username = $username -replace "%27", "'"
# Validate the username
if ([string]::IsNullOrWhiteSpace($username)) {
Write-Host "Username is empty or invalid."
exit
# Get the user object
$userObj = Get-ADUser -Identity $username -Properties MemberOf
if ($null -eq $userObj) {
Write-Host "User '$username' not found in Active Directory."
exit
# Loop through each group and remove the user
foreach ($group in $userObj.MemberOf) {
Remove-ADGroupMember -Identity $group -Members $userObj -Confirm:$false
Write-Host "Removed $username from group $group"
Can you advise how to correct it?
Thanks and regards,
Chandan
13 REPLIES 13
Hi @Community Alums ,
I will share the Zoom link when I get bandwidth today.
Vishal
Hi @Vishal_Jaiswal ,
It is not possible to join the zoom call , Can ypu suggest once.
Thanks and regards,
Chandan Patra
Najmuddin Mohd
Hello @Community Alums ,
Can you first try this by running from the Server in which MID Server is installed.
This may give more insights
Najmuddin
Hi @Najmuddin Mohd ,
I have done but still it is not working.
Thanks, and regards,
Chandan Patra
