Restrict Low-Priority Incident Creation via Point of Entry Field in Emergency Change
12-18-2025 05:22 AM
In the Emergency Change form, there is a field called Point of Entry, which is intended to accept high-priority incidents only. Normally, this field does not accept low-priority incidents. The lookup list for this field displays only high-priority incidents; however, when users use the New button from the lookup list, they are able to create low-priority incidents. Consequently, the Point of Entry field ends up accepting low-priority incidents through this method.
We need a way to restrict the creation or selection of low-priority incidents from the lookup list so that the field enforces its high-priority restriction consistently.
Can some please suggest what will be the best solution for this?
12-18-2025 06:31 AM
Yes exactly
12-18-2025 06:45 AM
if your users are satisfying Table.None CREATE ACL on incident then they will see New button
-> when users click on Lookup Icon
-> right click on list header and add Script in Omit New Condition
Note: ensure you give this in your script, I used problem_id field on incident, you replace with below in your one
if (RP.getParameterValue('sysparm_view') == 'sys_ref_list' && RP.getParameterValue('sysparm_target') == 'incident.problem_id')
answer = true;
else
answer = false;
Output: New button is gone in reference lookup but still shown in normal table list
Normal list shows
12-18-2025 06:54 AM
I implemented this solution earlier, but client didn't accept this as hiding new button is not the better solution. Is there any other way to do this
12-18-2025 07:55 AM
why hiding New button is not better solution?
It's better solution rather than playing with the ACLs
12-18-2025 06:58 AM
I have added below condition on UI Action - New on normal list
&&!(RP.getParameterValue('sysparm_target')=='change_request.u_associated_incident')
