Restrict Low-Priority Incident Creation via Point of Entry Field in Emergency Change
12-18-2025 05:22 AM
In the Emergency Change form, there is a field called Point of Entry, which is intended to accept high-priority incidents only. Normally, this field does not accept low-priority incidents. The lookup list for this field displays only high-priority incidents; however, when users use the New button from the lookup list, they are able to create low-priority incidents. Consequently, the Point of Entry field ends up accepting low-priority incidents through this method.
We need a way to restrict the creation or selection of low-priority incidents from the lookup list so that the field enforces its high-priority restriction consistently.
Can some please suggest what will be the best solution for this?
12-18-2025 07:21 AM
the solution I shared is best
If you don't want to use that -> then ensure your users don't satisfy table.None CREATE ACL on incident table
I believe I shared a working solution
12-30-2025 01:08 AM
Hope you are doing good.
