Need Help with mrvs in flow designer
tyagi_amrit2701
Hi all,
I can't use look up record in multi row variable set while using for each in flow designer .the field I am trying to access in multi row variable set is lookup select box,  is there any way through which I can use look up record in multi row variable set.
32 REPLIES 32
@tyagi_amrit2701
ensure Lookup value field on lookup select box variable is marked as SysId Field
Then it should work
@tyagi_amrit2701
which table is being referred by Lookup select box variable?
share screenshot
As per your image you are getting some encoded query i.e. certified=true
Hi @Ankur Bawiskar I am referring to software model table and certified = true is additional conditional that i need to check as well as per the requirement.
@tyagi_amrit2701
did you check this point which I shared earlier?
@Ankur Bawiskar If i change it to sys id  it is showing sys ids instead of names in the catalog itemflow 3.PNG
