Need Help with mrvs in flow designer
03-18-2025 02:28 PM
Hi all,
I can't use look up record in multi row variable set while using for each in flow designer .the field I am trying to access in multi row variable set is lookup select box, is there any way through which I can use look up record in multi row variable set.
Flow Designer
03-19-2025 05:32 AM
1 more workaround here
How to access Variables Set/Multi Variable Set Variables in a flow (Flow Designer)
03-19-2025 05:40 AM
it worked for me in this way
Don't give same name for the Object and Array of Objects here
Just give the name for Array of Object and don't give name for the Object when it gets created below it
03-19-2025 07:12 AM
@Ankur Bawiskar tried this but still getting error
03-19-2025 07:16 AM
it worked for me, as you can see in the image and gif both
Did you configure it in same manner? the subflow inputs etc?
Share your subflow inputs how you configured?
Ensure subflow is configured as Run as System User
03-19-2025 07:23 AM
@Ankur Bawiskar this is how i configured it and run as is still system user
