Need Help with mrvs in flow designer
03-18-2025 02:28 PM
Hi all,
I can't use look up record in multi row variable set while using for each in flow designer .the field I am trying to access in multi row variable set is lookup select box, is there any way through which I can use look up record in multi row variable set.
Flow Designer
03-19-2025 08:45 AM
Sorry but it worked for me.
Not sure if you have missed any step
03-19-2025 10:03 AM
Hope you are doing good.
03-18-2025 11:08 PM
you cannot directly use Lookup record in MRVS when using for each
check this how it can be done and enhance it from your side
Example:
Use Lookup Record on sys_user within your for each with condition as
SysId == For Each->MRVS->User
Then use output from Lookup Record and dot walk to Name field in next step
