how to Integration hub imbedded into flow designer
abdulrakhee
Tanushree Maiti
Hi @abdulrakhee
Integration Hub is natively embedded within Flow Designer as a low-code integration platform. It enables you to use pre-built Integration Hub Spokes or create custom API actions (like Rest API or powershell Action) that can be invoked directly within your workflows, allowing seamless integration with external systems without extensive scripting.
Refer: What is IntegrationHub and how do I use it?
Integration Hub Spokes and How to Build Them
REST Easy with IntegrationHub
e.g
