Background script
sparit3737
why bacground script is use in services now and whats is important in services now.
SohamTipnis
Hi @sparit3737,
Background Scripts in ServiceNow are mainly used to execute server-side JavaScript directly on the instance. They are useful for testing scripts, fetching records, updating multiple records, deleting unwanted data, and performing bulk data corrections. We generally use GlideRecord in Background Scripts to interact with ServiceNow tables. For example, if we want to update the priority of multiple incidents at once, we can do it through a Background Script instead of updating each record manually. It also helps developers test and debug their scripts quickly. However, we should always be careful while executing scripts, especially in production, because incorrect queries can affect a large number of records.
You can also refer the offical ServiceNow documentation notes:
https://www.servicenow.com/docs/r/api-reference/scripts/c_ScriptsBackground.html
https://www.servicenow.com/docs/r/platform-security/instance-security-hardening-settings/sc-restrict...
https://www.servicenow.com/docs/r/application-development/vscode-background-script.html
If you find my answer useful, please mark it as Helpful and Correct. ‌‌😊
Soham Tipnis
ServiceNow Developer || Technical Consultant
LinkedIn: www.linkedin.com/in/sohamtipnis10
