Flow Not Found After Publishing – “Content not found. Flow sys_id:p definition”
08-06-2025 04:45 AM
Hello Experts,
I’m facing an issue where my published Flow is not accessible anymore. When I try to open it, I receive the following error message.
Content not found
Your flow cannot be found. Flow sys_id:p definition
Steps Taken:
Created a Flow in Flow Designer under a Scoped Application in Instance A
Published the application successfully and installed in Instance B
But in Instance B it throws the “Content not found” error as shown in the below screenshot.
Thanks & Regards,
Srinithi. V.
08-07-2025 12:34 AM
Hi @srinitv ,
Probably some DEV(Instance A) plugin has not been installed in all environments, JSON Parsed or some other specific plugin that is only installed in DEV(Instance A).
Please follow below threads
https://support.servicenow.com/kb?id=kb_article_view&sysparm_article=KB0823104
BK
