Flow
RoshaniB
This is the script I have used for assigning group in workflow but it's not working for flow .
try using this script might work..
var task = fd_data.trigger.current;
var requester = new GlideRecord('sys_user');
if (requester.get(task.request_item.requested_for)) {
    var location = new GlideRecord('cmn_location');
    if (location.get(requester.location)) {
        task.assignment_group = location.u_it_fulfillment_group;
Ankur Bawiskar
@RoshaniB
where in flow did you use this? share that
I have used in flow catalog task in assignment group field
Hello @RoshaniB ,
why are using this line gr.query() in your code while you already used like gr.get(sys_id)
Hello @RoshaniB ,
Hello @RoshaniB ,
means you are using both requester.query() and requester.get(),  just use requester.get() . How you are using current object in flow script directly ?
