Flow
RoshaniB
This is the script I have used for assigning group in workflow but it's not working for flow .
try using this script might work..
var task = fd_data.trigger.current;
var requester = new GlideRecord('sys_user');
if (requester.get(task.request_item.requested_for)) {
    var location = new GlideRecord('cmn_location');
    if (location.get(requester.location)) {
        task.assignment_group = location.u_it_fulfillment_group;
yashkamde
Hello @RoshaniB ,
are you using this script in toggle script?
In flow while working with script generally we use fd_data object to get and return values.
