how to access MVRS variables outside mvrs for to autopopulate catalog item variables
sariksorte
Hi @sariksorte Please try this -
    var obj = JSON.parse(g_form.getValue('application_namespace_configuration'));
    alert(obj);
    for (var i = 0; i < obj.length; i++) {
        g_form.addInfoMessage(obj[i].app_nickname); //user is the variable inside mrvs
		obj[i].app_nickname = "HI";
	g_form.setValue('application_namespace_configuration', JSON.stringify(obj));
For me this script is working and setting the variables values inside the MRVS. Please let me know at which point in the script it is not functioning as expected?
12 REPLIES 12
onchange is on 'landscape' variable not on mvrs I want to populate 'nickname'(nickame is in mvrs) on 'jenkins_access_group_name'
Ankur Bawiskar
@sariksorte
so you want to access MRVS variables when you write onChange catalog client script on outside variable?
if yes then this syntax should work for you
var mrvsData = g_form.getValue('application_namespace_configuration');
Please share complete client script and what's your business requirement
Hi Ankur this syntax is not working
