Missing App Engine > Administration > App Engine Management Center option
LCristina
Greetings!
I have the following problem, after configuring the entire "App Engine Studio" options in all 3 environments, now I have to install the "App Engine Management Center", but the module "All > App Engine > Administration > App Engine Management Center" guide, is missing in all my environments.
This is my production instance at the moment.
Is anyone else facing the same problem?
A help would be much appreciated!
Thanks in advance.
Dr Atul - LNG
Hi @LCristina
Use the App Engine Studio (AES) App Engine Management Center guided setup to step through the initial configuration of the AEMC application. Detailed instructions for each step are provided in subsequent sections of the product documentation.
Before you begin
Role required: admin
https://docs.servicenow.com/bundle/sandiego-application-development/page/build/app-engine-studio/tas...
try cache.do
clear broswer cache
logout n login
Dr Atul - LNG
Hi @LCristina
Before you begin
try cache.do
clear broswer cache
logout n login
Hello @Dr Atul - LNG !
I've already checked the official documentation. As you can see, the "All > App Engine > Administration > App Engine Management Center" is not available in my production instance. I do have admin role and we are already in Vancouver version.
I appreciate the reply.
Log a now support case in this case.
