Not able to create application using App Engine Studio with existing template as well as from scratc
poojagupta75964
Not able to create applications using App Engine Studio, (tried to create app from scratch) getting following error:
"Template Execution Failure The template encountered an error when running. Contact your administrator if the issue persists."
Also when trying to create app using existing template getting below error:
Alert level: critical.
Template Execution Failure Error occurred while generating values for variables
jcamargo
Kilo Expert
 Hi There,
 I was having the same problem earlier today.
 To get rid of the error message, go to you developer home page and click on your logo on the right hand side to open your (My Instance) menu.
 From the instance action dropdown menu, click Reset and Wipe Instance.
jcamargo
Kilo Expert
 Hi There,
Thanks for your answer .
I already gone through the same steps as you suggested but issue is same with new one instance too after applying "Reset and wipe instance" option.
Hi ,
My issue got resolved after "Reset & wipe instance" option.
I don't know in first attempt why it was not worked but this time i didn't do "Reset & wipe instance" option with new instance creation but mark uncheck the option for creating new one instance after wiping .
Only after that issue was resolved.
Thanks for guiding us.
poojagupta75964
Hello Team,
Please support on the issue. I am still stuck to create app using App engine studio.
Highly appreciate for your quick and kind response.
Thanks!
