ServiceNow – Migrated records not initializing UI correctly until a field is changed
AshutoshS790709
I have migrated data from a legacy system into a custom table in ServiceNow using Load Data / Import Set.
When I open a migrated record for the first time, the form does not behave as expected:
  • Normally, most fields should be read-only except Assigned to, but on the migrated record almost no fields are read-only (except Primary Contact).
  • The Activity section (Work Notes and Additional Comments with filtering) is not visible.
  • The Resolution Notes section is also missing.
  • UI Actions such as Cancel and Resolve are visible, but they do nothing when clicked.
  • The form context menu (Save, Configure, Export, Show XML, etc.) is not available.
However, if I change the value of any field (for example, Issue) and click Update, then:
  • All read-only rules apply correctly
  • Activity and Resolution sections appear
  • UI Actions start working
  • The form context menu becomes available
Simply clicking Update without changing any field does not fix the issue — a real field change is required.
DipenduR
@AshutoshS790709  Did you find any resolution to this?
DipenduR
