SSO ISSUE
JackieZhang
We have encountered several issues during the SSO implementation. The client uses a self-developed IdP. First, we are unsure whether the SAML Request uses the GET or POST method. Second, When using the POST method, an error is reported stating that the method is incorrect. When using the GET method, the IdP side requires a certificate; how to generate ServiceNow's X.509 certificate?
Thanks for the follow-up @JackieZhang  — let’s troubleshoot this precisely. If ServiceNow is still rejecting the private key with a “not PEM” error, even after using the openssl pkcs8 conversion, here are the most likely causes and how to fix them
1. Check the Output Format
Ensure the converted file (saml_pkcs8.key) starts and ends with exactly
-----BEGIN PRIVATE KEY-----
(base64 content)
-----END PRIVATE KEY-----
If it says -----BEGIN ENCRYPTED PRIVATE KEY----- or -----BEGIN RSA PRIVATE KEY-----, it’s not the correct format
2. Use This Exact OpenSSL Command
openssl pkcs8 -topk8 -inform PEM -outform PEM -in saml.key -out saml_pkcs8.key -nocrypt
Important:
  • -nocrypt ensures the key is not encrypted — ServiceNow does not support encrypted private keys.
  • -topk8 converts from PKCS#1 to PKCS#8.
3. Verify the File Encoding
Sometimes the file gets saved with incorrect encoding (e.g., UTF-16 or with BOM). Make sure:
  • The file is saved as UTF-8 without BOM.
  • No extra spaces, tabs, or line breaks are added before or after the key.
Use a plain text editor like Notepad++ or VS Code and check the encoding.
4. Validate the Key Format
You can run this to check the key:
openssl pkcs8 -in saml_pkcs8.key -inform PEM -noout -text
If it throws an error, the key is malformed.
5. Paste Carefully into ServiceNow
When pasting into Multi-Provider SSO → Certificates → Private Key:
  • Paste only the key content.
  • Do not include any extra characters or metadata.
  • Make sure the field is set to type Private Key, not Certificate
If it is helpful, please hit the thumbs button please mark the answer as correct based on the impact!!
Kind Regards,
Shaik Mohammed Mustaq
And I found there is no different before I used cmd openssl pkcs8 -topk8 -inform PEM -outform PEM -in saml.key -out saml_pkcs8.key -nocrypt and after
If there’s no difference between the original saml.key and the converted saml_pkcs8.key, then your original key is probably already in PKCS#8 format, meaning the conversion command doesn’t change anything.
But here’s the catch: even if the format is correct, ServiceNow might still reject it due to encoding, header mismatch, or invisible characters.
Check header and footer Open both files in a plain text editor and confirm
(base64 content)
  • -----BEGIN RSA PRIVATE KEY-----
      → PKCS#1 format
    • -----BEGIN ENCRYPTED PRIVATE KEY----- → Encrypted, not accepted
    • -----BEGIN EC PRIVATE KEY----- → Elliptic Curve, not supported by all IdPs
    If your original key already says BEGIN PRIVATE KEY, it’s PKCS#8 — but still check the encoding.
Run this to confirm it’s a valid PKCS#8 key
openssl pkcs8 -in saml.key -inform PEM -noout -text
If it works without error, the key is valid. If it fails, the key is malformed or not PKCS#8.
Header is correct but Servicenow was not accept.  Then I found an another way to transform it  to pkcs12, then servicenow can accept it . but I don't know if it worked.
