Tables and Relationships
sunilsargam
Hello All,
I’m looking for a way to identify a specific table in ServiceNow along with all the tables that are related to it. In other words, if I have one table, I want to know all other tables that are connected or associated with it.
Is there a method or feature in ServiceNow that can provide this information?
Thank you in advance
9 REPLIES 9
Abhijeet_Pawar
Hello @sunilsargam ,
ServiceNow provides an easy way to identify a table and all the tables related to it by using the Schema Map feature.
How to access it:
  1. Go to System Definition → Tables.
  2. Open the table you want to analyze.
  3. Click on Schema Map from the top-right menu.
What Schema Map shows:
  • Tables that extend your table (child tables)
  • Tables that your table extends (parent tables)
  • Tables that your table references
  • Tables that reference your table
This gives a complete visual view of all associations and relationships for the selected table. Additionally, you can check the Dictionary and Referenced By related lists on the table for more details.
Hope this helps!
@Abhijeet_Pawar
the info you shared was already shared by other 2 members.
Any reason to repeat the same info?
Ankur Bawiskar
@sunilsargam
info is already shared by @Dr Atul - LNG
sharing docs link for your reference
Viewing table references and extensions
Hello @Ankur Bawiskar
Good day!!
Thank you for the above steps. However im looking something where i can see this all as in records rather than visual representation.
my end goal is - if user selected any table record, i need to export that record and related all the records for that particular records. Im looking if this can be feasible or not in ServiceNow.
Thank you
Sunil Sargam
@sunilsargam
not feasible.
