Unable to properly call a UI Script from a Catalog Client Script.
RyoyaFukuda
Hi,all.
I am trying to call a UI Script from a Catalog Client Script.
This development is being done within a custom application.
Here is the script. And error message is ''UI Script  x_16799_test.TestUIScript is loaded but can not find dummyFunction or result is fraud. Result: null'
Could you please tell me why the UI Script cannot be called successfully?
Type : onChange
UI Type : All
    var value = newValue;
    var name = 'u_int_test';
    var uiScriptName = 'x_16799_test.TestUIScript';
    if (typeof g_ui_scripts !== 'undefined') {
        // Workspace(WEP)
         g_ui_scripts.getUIScript(uiScriptName).then(function(result) {
        if (result && typeof result.dummyFunction === 'function') {
		//  if (result && typeof result.formatAndTruncateNumber === 'function') {
            g_form.addInfoMessage('UI Script ' + uiScriptName + ' is loaded and find dummyFunction');
            result.dummyFunction();
            g_form.addInfoMessage('UI Script ' + uiScriptName + ' is loaded but can not find dummyFunction or  result is fraud.  Result: ' + JSON.stringify(result));
    }).catch(function(error) {
        g_form.addErrorMessage('UI script failed to load: ' + error);
UI Script
API:x_16799_test.TestUIScript
(function() {
    return {
        dummyFunction: function() {
            // do noting
@Tanushree Maiti
@Ankur Bawiskar
I successfully called it. Thank you very much.
However, another problem has occurred.
I tried to get the length of a string by writing str.length in the UI Script, but the following error message appeared in the console: "Cannot read properties of undefined (reading 'length')"
'g_form.showFieldMsg' also cannot be used in UI Script.
@RyoyaFukuda
Glad to know that my approach worked for you.
Would you mind marking my response as correct and close the thread?
Ankur Bawiskar
@RyoyaFukuda
you are running this script in native or portal?
Ankur Bawiskar
@RyoyaFukuda
check this
[SOLVED] How to call scoped UI script from catalog client script ?
