Why cancel button for problem is not working for workspace?
01-22-2025 01:43 AM
Hi Team,
Cancel button is not working for Problem.
Script :-
This is the OOTB button,
same button is working in m py PDI also after clicking cancel button state changes to root cause analysis, but after that again clicking on cancel its not working?
what could be the issue, only workspace script I can see few lines added, I dont think those lines are reason of issue, also tried to remove them
01-22-2025 01:58 AM
did you add the workspace client script lines from your side?
If yes then action object won't work in client side.
what's the button doing? Is it changing the state to cancel and reloading?
If yes then something similar can be done in workspace client script as well
01-22-2025 02:14 AM
Hi @Ankur Bawiskar ,
Line are added for making close notes mandatory.
I am trying to change the state close here
01-22-2025 02:24 AM
so you want to make close notes mandatory in workspace client script?
If yes then simply check value and if empty then make mandatory and use return statement
you can find lot of OOB UI actions with similar workspace client script
Did you check that?
01-27-2025 01:26 AM
Can you tell me syntax for return statement
