MS Graph / OAuth 2.0 Integration - Best practice questions and issues
Tom Sienkiewicz
Hi, I really hope someone who has had some success properly implementing the Authorization code flow for MS Graph API can point me in the right direction as I feel I am missing some bits to fully understand the integration.
I have built my integration with MS Graph and it is working fine. I am requesting Access tokens, getting those and successfully using the Graph API to interact with e.g. Calendars or Mail. So you might ask, what's wrong?
Well, it appears to be running fine but I feel it is still not perfect. It really depraves me of valuable sleep. So, let me break down the issues I feel I have:
1. In the Application Registry, I have added my application and then the OAuth Entity Profile, with the Grant Type "client_credentials" and the Scope "https://graph.microsoft.com/.default":
So why is ServiceNow forcing me to add the Grant type and Scope again when constructing my token request??? This works:
var tokenRequest = new sn_auth.GlideOAuthClientRequest();
tokenRequest.setGrantType('client_credentials');
tokenRequest.setScope('https://graph.microsoft.com/.default');
var oAuthClient = new sn_auth.GlideOAuthClient();
var tokenResponse = oAuthClient.requestTokenByRequest("Azure AD Token", tokenRequest);
BUT THIS DOESN'T and gives an error:
OAuthProblemException{error='invalid_request', description='AADSTS900144: The request body must contain the following parameter: 'grant_type'.
OAuthProblemException{error='invalid_request', description='AADSTS90014: The required field
'scope' is missing from the credential. Ensure that you have all the necessary parameters for
the login request.
So, what's the point of adding all that to my Application Registry?
Or am I missing something here/using the wrong API?
2. Obviously, using "client_credentials", we cannot utilize the Refresh Token. The question is, is "Authorization Code" approach generally more recommended?
If yes, why? Can this approach work with "Application" permissions, or only with "Delegated" permissions? As I understand, Application > Delegated, right?
So, I created another Application Registry profile, this time with "Authorization Code" grant type, set everything up, created OAuth 2.0 Credential,
clicked the "Get OAuth token", got the pop-up where I had to click "Accept" - perfect. There is a new token in the Tokens table:
Now I get lost a bit and here are my questions:
- The pop-up with request for authorization appears only at the set-up and not every time the integration is fired, for every user, right? Sorry if that's a noob question.
It seems it would be really annoying if ServiceNow asked every user to click "Accept" before it can check their calendar. Then again, it seems to work based on impersonation...
- I understand that you only have to click the "Get OAuth token" link once and then the Refresh token should get a new Access token before it expires right?
In my case, the Access token expired after an hour and nothing else happened. I don't even know if I received the Refresh token - seems I did not. Also, why is the token field empty?
- how do I get the Refresh/Access tokens to run fully auto in the background? Is it not provided OOTB? Is there a specific API I have to use?
Do I need to write my own logic to get the Refresh Token, monitor the Token table to see if any Access token is active and if not, manually trigger
the generation of new Access token with Refresh token?
- What is the recommended way to trigger the REST service? Create a record in Outbound REST and link
it to the credentials? Or just trigger REST from script and build the whole Request header/body with authorization there?
Many thanks for any pointers in the right direction. It is hard to find valuable examples online, everyone seems to be using the "client_credentials" approach, I have not seen an example of setting up the Authorization Code end to end.
So I really hope someone can shed some light here. I even tried to install and run the Integration Hub spoke for "Exchange Online" as they use this approach there,
but could not see how it handles Refresh tokens...
Sorry for the long post but hopefully everyone can benefit from the answers/discussion 🙂 thanks!
17 REPLIES 17
I'm tying this API https://graph.microsoft.com/v1.0/devices
and no I'm not building a post request to get the token, I was just looking into the node file and saw the post request to get the token
Hi Khadija,
In your script, you posted earlier - seems you are trying to get the token on your own. (But you are saying "no"!!!)
1. Create a REST Message for https://graph.microsoft.com/v1.0/devices and use Authentication Type = OAuth2.
2. Setup the Auth Profile as I have described in the first reply.
3. In the script: Just call the REST message (created in 1) without any mention of authentication. ServiceNow falls back to the Authentication Type & Profile you setup in Point No 2, all the access token fetching and refreshes will be taken care automatically.
BTW, you should use RESTMessageV2 class to fire the webservice calls and DO NOT use GlideOAuthClient (this is for different purpose).
Poorna
Well if it is Graph 1.0 API there should not be anything unusual about it.
The error you were getting 'invalid audience' might suggest that you are not using the correct scopes or that your application is misconfigured in MS Azure. Or perhaps you use some proxy which is messing it up.
check here
https://docs.microsoft.com/en-us/graph/api/device-list?view=graph-rest-1.0&tabs=http
and make sure your app has the correct permissions assigned in Azure and that you are using the correct scopes as described above.
There is probably a different token endpoint needed when you use single/multi tennant in Azure so make sure to check that as well...
