Need help for JSON formatting
Vidya Shree
I am trying to fetch the variables and it's values populated while creating record producer in a server script.
Using GlideRecord on the Record producer base table is not working. So, I am using GlideRecord on 'sc_multi_row_question_answer' to get the values. Currently I am getting below response
"preImplementationPlan ": [
"duration2": "3 hrs"
"implementation_plan2": "testing plan"
"teams2": "NOC"
"teams2": "db team"
"duration2": "2 hrs"
"implementation_plan2": "testing db team"
But expected response is as below
"implementation_plan2": "testing plan",
"teams2": "NOC"
"implementation_plan2": "testing db team",
"teams2": "db team",
Below is the code that i am using
var Arr = [];
var test = {};
var mrvs = new GlideRecord('sc_multi_row_question_answer');
mrvs.addQuery('parent_id', '5ef3c42593ba4210d783bba97bba10b0');
mrvs.addQuery('variable_set','ab4ea5b4937a4210d783bba97bba10a7');
mrvs.groupBy('row_index');
mrvs.query();
while (mrvs.next()) {
var preImplementationPlan = {};
 preImplementationPlan[mrvs.item_option_new.name.toString()] = mrvs.getValue('value');
Arr.push(preImplementationPlan);
test["preImplementationPlan "] = Arr;
gs.addInfoMessage(JSON.stringify(test));
Hi @Vidya Shree ,
there is an issue with your code.
the issue in your code is that it created a new object for each variable within the loop and pushed it directly to the array. This resulted in each variable being a separate object in the array, rather than grouping variables with the same row_index together.
Original Issue:
Your code created a structure where each variable was a separate object in the array:
"preImplementationPlan": [
{"duration2": "3 hrs"},
{"implementation_plan2": "testing plan"},
{"teams2": "NOC"},
{"teams2": "db team"},
{"duration2": "2 hrs"},
{"implementation_plan2": "testing db team"}
Desired Structure:
You wanted the variables to be grouped together by row_index:
"teams2": "NOC",
please find the below updated code
var Arr = [];
var test = {};
mrvs.addQuery('variable_set', 'ab4ea5b4937a4210d783bba97bba10a7');
mrvs.orderBy('row_index'); // Ensure that results are ordered by row_index
mrvs.query();
var currentRowIndex = null;
var rowIndex = mrvs.getValue('row_index');
if (currentRowIndex !== rowIndex) {
if (currentRowIndex !== null) {
currentRowIndex = rowIndex;
// Add the last set of variables
if (Object.keys(preImplementationPlan).length > 0) {
test["preImplementationPlan"] = Arr;
Please give it a thumbs up and solution accepted if your issue is solved.
Sanjay Kumar
Vidya Shree
Hi @Community Alums ,
Thank you so much.
The script worked.
