ARTICLE: Platform Analytics common Issues and their fix
RiteshSwarnakar
Giga Guru
1) Issue: Filter not getting applied on indicator when multiple choices are selected in filter.
Fix: Make sure it is checked RiteshSwarnakar_0-1748710653440.png
2) Issue: Data Visualizations / Widgets not following the filters
Fix: Try clearing all filtersRiteshSwarnakar_1-1748710786134.pngIf above does not work then, the node cache has to be cleared with help of Now support engineer
3) Issue: Dynamic filter doesn't work in Indicators (KB0860136)
Fix: Add the dynamic filter condition using "Configure values"
4) Group By Showing Unassigned like this:      RiteshSwarnakar_1-1749129996557.png
Cause: Check Breakdown Source "Label for unmatched" field
Will continue to add more points
0 REPLIES 0
