Need help with the script
Nani5
I have a catalog Item where in I have 3 different variables (Indevelopment,Preposition,Live).I have a table "which stores the dates in multiple records meaning Indevelopment of CI will have 1 record with start date,Preposition of CI will have 1 record with start date etc...
Need to retrieve the start dates and fill it in the Item form.Tried with below script but multiple record values I need in same form.
var indev='';
var preposition='';
var live='';
var CIRecord = new GlideRecord('x_inpgh_upmx_pf_lifecycle_breakdown');
CIRecord.addQuery('cmdb_ci','4ac3006487673050d19aecec3fbb356d');
CIRecord.query();
while(CIRecord.next()){
    var arr=[];
arr.push(CIRecord.lifecycle.name+','+CIRecord.start_date);
gs.print("ARRAY>>>>>>"+arr.toString());
for (i=0;i<arr.length;i++){
    gs.print("Inside FOR>>>>"+arr[i]);
@Nani5,
For each record create an object and push it into the array like this:
var obj = {
"name":CIRecord.lifecycle.name,
"date":CIRecord.start_date
arr.push(obj);
access the values like this:
    gs.print("Inside FOR>>>>"+arr[i].name + " " arr[i].date);
Hello Jake,
Thanks for the quick reply and fix.
Since I am trying to retrieve the date field,I have used .getValue() and below is my modified script with logs.
var indev='';
var proposition='';
var live='';
  var arr=[];
CIRecord.query();
 var obj = {
"date":CIRecord.start_date.getValue()
arr.push(obj);
//arr.push(CIRecord.lifecycle.name+','+CIRecord.start_date);
//arr.push(JSON.stringify(arr));
    gs.print("Inside FOR>>>>"+arr[i].name + "," +arr[i].date);
    //gs.print(arr[i].name.indexOf('Phase-out'));
    if(arr[i].name.indexOf('In Development')>-1){
indev=arr[i].date;
    if(arr[i].name.indexOf('Proposition')>-1){
proposition=arr[i].date;
    if(arr[i].name.indexOf('Live')>-1){
live=arr[i].date;
gs.print("INDEV>>>>"+indev);
gs.print("PROPOSITION>>>>"+proposition);
gs.print("LIVE>>>>"+live);
Result in background Script:
*** Script: Inside FOR>>>>Proposition,
*** Script: Inside FOR>>>>Live,2023-01-31
*** Script: Inside FOR>>>>In Development,2021-10-28
*** Script: INDEV>>>>2021-10-28
*** Script: PROPOSITION>>>>
*** Script: LIVE>>>>2023-01-31
