AWA Advance Work Assignment is not working.
basantsoni
Mega Guru
Good Day!
I was looking for a solution in ServiceNow where I have to route cases/incidents to an assignment group and whoever is an available agent from Group then assigns cases to that agent's. I have read ServiceNow documents and communities and we found that there is Application in ServiceNow AWA Advance Work Assignment where we can define and achieve this.
As per ServiceNow documents I have created Service Channel/Queue and Assignment Eligibility but when we are raising cases/incidents nothing is happening. We are doing all of this innovative UI and we are using Agent workspace.
To achieve this , Please provide your valuable response.
9 REPLIES 9
Looks like you have done everything correct 🙂
Just set the state to available in agent workspace as Abel and the work items showed up in the inbox.
I think you are ready to go.
Hi Thomas,
Sorry for the late reply, and thanks for your valuable response.
So in this design, Based on conditions in Service Channel and Queue , tickets will be routed into available agents inboxes in Agent Workspace.
In another window, I logged in with another browser with user # Able Tutor.
But, I'm creating cases and incidents as per define conditions for Service Channel but tickets - cases and incidents are getting assigned onl into Queue and it's not coming into Agents inboxes. I have checked Work Items In-assignee and I can see the state is Queue only.
Can you please take a look at where I'm making a mistake.
S Ram
Hi, Any luck with getting this to work? I'm having the exact same issue where I have configured Service channels/queues/assignment eligibility etc...but when a work item is created its not assigning to the group.
Any help would be greatly appreciated, thanks!
S Ram
@basantsoni The issue finally got resolved at my end. Pls have a look at this article that I just published which articulates the issue along with the steps taken to resolve: https://community.servicenow.com/community?id=community_article&sys_id=b45bb8b5db8af858fb115583ca961932
S Ram
