copy additional comment & worknotes from incident to case .
yunus shadman
how to copy the additional comments and worknotes from incident to related case record . i have already tried with the BR (before - update )
table- incident
    var relatedCase1 = new GlideRecord('sn_customerservice_case'); // initialize case table
    relatedCase1.addQuery('incident', current.sys_id);
    //relatedCase1.addActiveQuery();
    relatedCase1.query();
    if (relatedCase1.next()); {
        relatedCase1.work_notes = current.work_notes;
        //relatedCase1.update(); //updates changes
})(current, previous);
i have already tried to run the code but it is not working , i am a beginner , i dont know how to done programming properly , help me to find the solution so that i can understand easily.
Yousaf
Hi Lakshmi,
You need to add additional condition in BR to prevent it from copying recursively. Change variable names according to your requirement please.
current.comments.indexOf('Worknotes added from incident') < 0;
Copy task comments and worknotes to parent request item
Reference : Copy work notes/Additional comments from Incident to Incident task and vice versa
Mark Correct or Helpful if it helps.
