copy work notes to work order from workorder task
Hi All
I want to copy worknotes of workorder task (wm_task) to workorder worknotes  (wm_order).
Please can guide and suggest me the script please
Thanks.
Please add logs and check if process trigging.
Also add the current.update(); for [ testing only ], If its working means we need to update work_order record differently  because current [ object ] belong to wm_task not the wm_order.
Use the below code in the BR and share the result.
var grWmOrder = New GlideRecord("wm_order");
      grWmOrder.addQuery("sys_id",current.wm_order); // wm_order is reference field on wm_task
      grWmOrder.query();
  if(grWmOrder.next()){
          grWmOrder.work_notes = current.work_notes; // update the work note from task to order
          grWmOrder.update();
      grWmOrder.query();
          grWmOrder.update();
Good to see that your issue resolved, happy to help. 😊
Yes @AshishKM Appreciate for your help
Its helped my requirement
Thankyou.
