How do i concatenate address using business rule.
Alok21
Giga Expert
Hi Team,
I have a requirement to concatenate few fields into a string field and i am not sure how i can achieve this.
The address field should be concatenated as below.
DEUTSCHE BANK
Technik Niederlassung West
Field Operations Mobile (T-MRF)
Detmolder Str. 380
33605 Bielefeld
Germany
Can someone please assist on this?
Alok sahu
Hi Ankur,
The issue has been fixed. I just increased the max length of the field to 300 and it worked 🙂
Alok sahu
Hi Ankur,
Yes it is a string field and hence i am having the issue. Do i need to change the field type and if yes, what it should be?
Alok sahu
Hi Ankur,
Alok sahu
Glad that it worked.
Can you mark my answer as correct, helpful if you were able to achieve the requirement. This helps in removing this question from unanswered list and helps users to learn from your thread. Thanks in advance.
Hi Alok,
Did you accidentally mark your own answer as correct?
