How to create Problem Task automatically when problem record is moved to Root cause analysis state using flow designer ?
Balakrishna_ABK
How to create a Problem Task and populate description of problem automatically when problem record is moved to Root cause analysis state using flow designer ?
then during Problem task creation in flow action; set the type field to RCA
Ankur Bawiskar
So what have you started with and what is not working?
I tried but I can't see problem task created in related lists
I have shared solution
you need to populate the problem field on problem_task so that the problem task is shown in related list
Check below screenshots
Thanks Ankur for your quick reply. The only thing is I want task to be RCA type created but by default it is creating general task.
