How to create Problem Task automatically when problem record is moved to Root cause analysis state using flow designer ?
Balakrishna_ABK
How to create a Problem Task and populate description of problem automatically when problem record is moved to Root cause analysis state using flow designer ?
then during Problem task creation in flow action; set the type field to RCA
Sorry didn't get you.
Can you explain in detail?
Actually by default it is creating General task I want RCA task to be created
It's working, thankyou very much Ankur
Hi Ankur, how to create flow for "Without completing the Problem RCA Task the Problem state should not go to 'Fix in progress' from RCA ".
