How to Solve 'onChange script error: RangeError: Maximum call stack size exceeded function () { [native code] }' Error.
Hi Team,
i am trying to hide/show choice values of status filed(state) based on status field only. but i am getting onChange script error: RangeError: Maximum call stack size exceeded function () { [native code] } this error.
Please let me know how to solve this one.
below is my sample code.
if (newValue == 1){
g_form.addOption('state', 7);
else {
if (newValue == 10 || newValue == 18 || newValue == 6 || newValue == 3){
g_form.removeOption('state', 7);
Thank you,
Hari Kishan.
@HARI KISHAN GVS
you can run onload client script and run it only for existing records and not new one
function onLoad(){
	if(!g_form.isNewRecord()){
		var val = g_form.getValue('state');
		if (val == 10 || val == 18 || val == 6 || val == 3){
12 REPLIES 12
Upender Kumar
there is extra } in the code.
Can you share full code.
	if (newValue == 1){
	else {
Ankur Bawiskar
I agree with point mentioned by Maik.
It will go in loops.
What is your business requirement here?
Hi Ankur,
my requirement is, show cancelled choice value in the choice list if state is new. for all other states hide the cancelled choice from the list.
by Default, when form opens (at creation of case) it will be in new state only.
Hari Kishan.
try updating as this
    if(oldValue != newValue){
        if (newValue == 1){
        else {
