ā09-24-2021 01:32 AM
Hi Team,
i am trying to hide/show choice values of status filed(state) based on status field only. but i am getting onChange script error: RangeError: Maximum call stack size exceeded function () { [native code] } this error.
Please let me know how to solve this one.
below is my sample code.
if (newValue == 1){
g_form.addOption('state', 7);
else {
if (newValue == 10 || newValue == 18 || newValue == 6 || newValue == 3){
g_form.removeOption('state', 7);
Thank you,
Hari Kishan.
ā09-24-2021 02:42 AM
you can run onload client script and run it only for existing records and not new one
function onLoad(){
if(!g_form.isNewRecord()){
var val = g_form.getValue('state');
if (val == 10 || val == 18 || val == 6 || val == 3){
ā09-24-2021 02:58 AM
Hi Ankur,
it is working Partially, when i changing from new to open, cancelled is hiden. and when i changed from open to new, still cancelled is hidden. that should not happen.
Hari Kishan.
function onLoad(){
ā09-24-2021 02:56 AM
Hi Ankur,
onLoad is working as expected, but each time i need to save the form. i need to acheive this in Onchange.
Thank you,
Hari Kishan.
